Is it possible to increase the size of the screen print?
Marconi
Honorary Member Silent Key
Oct 23, 2005
7,235
2,325
343
Houston
I think I noticed recently that the size of the type set for the forums screens got smaller. I have trouble with my eyes and have trouble reading small print. I can make the type larger for my posts, but that is not the problem.
Is there a setting I can use to make the type look larger?
Nothing has changed on the site however you may have inadvertently changed something on your end. Is everything smaller? Changing screen resolution will change the size of everything on your screen.
I don't recall when I noticed the WWDX screens appearing in smaller type set...but maybe I could have done that inadvertently. Just pressing Ctrl and + or - at the same time...seems easy enough to do accidentally.
Marconi I went and got me a 39 inch flat screen with vga and hdmi inputs, now I
do not need my glasses to read the print
Every now and then I will be typing away and look up at my screen and the punctuation characters are no longer in English. LOL Still trying to find the keystroke combination that does that.
Ctrl and 0 will put everything back to normal after you've zoomed in or out.
Reactions: Marconi
firefox menu: edit> preferences> content lets you set font size. i also use one of the many zoom addons. i usually just hold ctrl and spin the mousewheel than +/- as it is faster. i don't recommend ridiculously large monitors for a pc as up close they are painful to look at, the neck rotates back and forth to follow the cursor. a friend of mine has a 40 inch screen that he is happy with but i could not use it comfortably. big screens are fine for a tv at the other end of the room imo.
