Looks interesting. Was wondering if anyone ran one of these. Any thoughts? http://www.lightningantennas.com/mobile/
Good reviews according to the site testimonials. I'm not in the financial situation where I can drop 100+ on ANOTHER mobile antenna. Especially right after Christmas. Guess I'll stick w my trusty 108 whip for now.
All I noticed from the pic is it seems to violate one of the rules of loading an antenna, the capacity hat appears to be too close to the coil.
I would expect less local vertical performance than a Whiskey still type mobile antenna.
If I had one of these I'd add 12"-18" between the coil & cap hat and remove a winding or two.
Seems a bit pricey for an oddly shaped mobile antenna, even if it does have almost 1/2 the amount of magic Antron9.9 gain
"Minigrass"?Forgot the guys numbers but when skips running from here to Hawaii. There's a guy running running one on his pick up that works good for him. He is a regular skip shooter from Honolulu. Great sounding station with a HR 2010 and a helper. Some of you probaly know him too.
I'm impressed and surprised by the plot compared to a full 1/4 wave vert. It is also the heart of the Merlin 55 which is basically what you show in your top plot.
Try it with a foot of mast above the coil & below the cap hat to see if it improves.
NB, below are two additional models that I did with this coil located 24" and 36" inches along the GR45 original 48" length instead of at the top and 2" inches below the top hat.
I'm surprised that at the 24" coil location the matching reactance abruptly went high. There may be a tipping-point somewhere, going down with the coil, between the 24" and 36" locations where the theory, not to place a coil near a top hat, comes into play.
IMO, and to be fair, this suggest to me I have to experiment with the coil location near the base too and then make a comparison. To check this out I will have to make the coil work starting at the base, get it working, and then going up toward the top hat as well.
If I can get this model with a top hat to respond well with a coil at the base...then I will raise it up 12" inches at a time and see what happens. Doing this the antenna may then show us more gain at the base and that will change the idea I just posted.
NB I say this, but I predict the first models I did above, which appears to disprove the theory you questioned above, actually reveals to us...within reason there is no disadvantage to placing an inductive coil near a top hat...and this design could be a small advantage instead. I have already proved this for me and presented the evidence, but how do you see it? Just for grins, you touched on the proof in your first sentence above. Go back and check my first GR45 model project carefully, and see if you see where I've already proved what we see in my first models.
No, I meant raising the top hat a foot above the coil but leaving the full height of the coil (5' total), or maybe drop the coil a foot but keep the total height (4' total).
Oh wow, I've just found this post, missed it for a couple weeks.I set the top hat 10" inches higher, and it moved the top hat to 12" above the top of the coil, see wire #64 is 12" inches. This added + reactance to the antenna and the match went bad.
The model I posted above showing wire #1 at 36" inches places the coil 12" below the top hat.
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
