2 meter base station & distance?
Bearcat
357
56
52
For 2 meters I want to talk simplex as far as I can..fm not ssb...what equipment will help me to achieve this? I can get up about 40ft and plan on getting a verticals beam..
you will need a 2 meter radio that modulates on fm
check your 2 meter band plan for frequencies designated for fm simplex, find a frequency that is not busy.
Reactions: Bearcat
I have the radio...power supply..I want as much distance as I can get!
That simply means you need the biggest antenna YOU can manage mounted as high as YOU can manage and as much power as YOU can reasonably afford. A good preamp mounted at the antenna is also advised for optimum receive. there is NO hard and fast rule of what YOU need other than YOU deciding what YOU can afford or manage to install. As usual bigger and higher is better than small and low. It's all about maximizing gains and minimizing losses with everything from the power output to the coax cable losses etc.
Reactions: Bearcat
When you say pre-amp...can a pre-amp be in the shack or are they just for antenna application?
Use some LDF4-50A, N-male connectors, like stated, get antenna as high as possible and the biggest one you can get up!! And the pre amp at the feedpoint like stated. You might be better off looking into a used repeater system. Just saying.
Reactions: Bearcat
Like Beetle said above the best place for a preamp is at the antenna feedpoint. Once a signal falls below the noise floor of your receiver or preamp it cannot be recovered. By placing a preamp at the antenna end of the cable you eliminate the losses of the cable and have a stronger signal for the preamp to work with.Having said that I did run a preamp at the shack end for quite some time and it worked great HOWEVER I had a relatively short run of LDF4-50 heliax cable and the losses were next to nothing even at 2m amounting to less than 1 dB so it was virtually like the preamp was at the feedpoint. I live in a rural area where noise levels are very low so there was zero noise pickup on the coax line as well. That is all gone now but I look forward to getting it all back bigger and better than ever in the summer.
Reactions: 222DBFL and Bearcat
Are all pre-amps the same? Any good ones out there? DX engineering has one for $139..I didn't know you mounted them at the antenna feed point until you guys mentioned it...but if I run really good coax and have a low noise level I could run it to the shack? I live in a very small town and up on a hill
Having a pre-amp at each location ( shack and Tower mounted) I can say the tower mounted pre-amp excels. I use them for 6 mtr's and the tower version works much better.
My coax run is very short ( less then 60 ft.)(LMR-400) and the pre-amp at the shack is almost never used.
The pre-amps in my rig are turned off and the tower mounted pre-amp is only thing used 90% of my operating time...I would expect the same if not greater results on 2 mtr's...as the comparable loss on 6 mtr's vs 2 mtr's....2 mtr's is even greater....
All the Best
Gary
All the Best
Gary
Can u run both?
Can u run both?
No not at the same time. The signal overload would be horrendous and cause all sorts of problems with the receive. You will start hearing commercial stations that are not even operating on 2m. Any preamp used must be capable of handling the full transmitter power BTW as it has to switch out of the circuit during TX.
Lol...noise pollution..so my preamp must handle whatever power I'm transmitting...learned something new!
  • @ nfsus:
    RFactive has left the room.
