KLV 550 amp.
Ronald Porter
Apr 8, 2016
23
5
13
81
would like to know the hookup of the 4 wires from the switches go on the under side of the board?
the schmatic diagram does not show them,and what order they go. color coded. brown,yellow,orange, and green. were unhooked when the amp came to me. Could anyone help me put them back in the right order. thank you, Ron
Ron
I can help you. Let me study my schematics and I also have one of those amps in stock in my shop. I will take my schematics and sit down with the amp and clear it up for you. I will measure point to point and post it here for you.
Reactions: tecnicoloco
Thank you, I don't want to turn it on with those wire's in the wrong location, Ron
As it is oriented below the colors are as follows from bottom to top.
1) Green, goes to the Pre TUNE pot. (R8 on the schematic)
2) Yellow, connects to the AM/SSB switch.(S1 on the sch.)
3) Orange, goes to Pre. on/off switch (S2 on the schematic)
4) Brown connects to the READY/St.By switch.(S3 on the schem.)
That's how this one is wired and I hope it helps you out.
thank you, working fine now. Ron
  • @ wavrider:
    sea que sea que,
    C'mon let me take you on a Sea Cruise! (Maybe there is someone to talk to out there?)
    Just for the Halibut.
    Seems to be dead on the radio lately. I don't know if the conditions are horrible, or more likely my weak antennas. I may head up in the mountains on Wednesday and see if reception / transmission is improved.
