What is this part?
johnecashflo
Wish I Was Here
Mar 26, 2007
129
4
28
INDIANA
This part came out of the linear plate on the bottom of a 4300-300. I replaced all the pills and with both fuses in it would keep kicking my breaker on my power supply. With only the number one fuse I could get half the board to work. Removed this piece from the board near fuse number two and now I have full power (over 300 watts). And it seems to receive ok. I was just wondering if anyone can tell me what this is. I would like to replace it or does anyone know if I can run the radio without it with no harm to the board. Cb tricks has a schematic but no part numbers. Thanks for any help you can give a novice
View attachment 18150 This part came out of the linear plate on the bottom of a 4300-300. I replaced all the pills and with both fuses in it would keep kicking my breaker on my power supply. With only the number one fuse I could get half the board to work. Removed this piece from the board near fuse number two and now I have full power (over 300 watts). And it seems to receive ok. I was just wondering if anyone can tell me what this is. I would like to replace it or does anyone know if I can run the radio without it with no harm to the board. Cb tricks has a schematic but no part numbers. Thanks for any help you can give a novice
Q3 2sd999
of course you need it
Reactions: BBB
  • @ nfsus:
    RFactive has left the room.
