Can I hook up through an rf sampler?Don't plug in an antenna to keep from overloading the front end of the radio and wear headphones to prevent feedback.
I don't have to run it through a scope.... I just want to hear it preferably without headphones.Well you did just say hear it. Feedback will be an issue without headphones if you are talking and listening at the same time. You will need to demodulate the RF sample and then run it thru an amp to hear it if you just want to pick off a sample that goes to the scope.
OK yeah, I didn't know if that was alright or not. I guess I could just run an ext. speaker to make it louder. With the demodulator do you hook it up to the back of the bench radio? How ishe it connected?I'm not sure what your looking for, but I just have a bench radio off to the side. Whatever I am working on is picked up by it, just a radio,mic and power you don't even need an antenna to hear.
That's badass! I'm definitely buying oneor get this if you do not want to build one
http://www.ebay.com/itm/AudioSample...390674?hash=item4b08cfe992:g:1uEAAOxycmBS3f4u
This is the one I use
