Monentary on or off? Did you try Mouser electronics?Does anybody happen to know where to find a switch like this one?
It's a momentary on double pole double throw but I haven't checked Mouser yetMonentary on or off? Did you try Mouser electronics?
Does anyone know where to get this switch now days?lol jaja oops ment Mic... thanks
here's the finish M I C tested it and no more scratchy sound and PTT is now nice and smooth
ebay item number for this interested is 281758269364
Thanks for the link. I just got one of these mics and the button is so hard to push that I thought it was broken. I push it in like normal and the radio keys but no audio. I double checked the battery and looked over the PCB; everything looked ok. Then I figured out that I was only pushing the button in half way. I need to pop the cover off again to see if something else is making it hard to push. I will probably change the switch anyway just because.
Is this the same switch, or a better version?
I'm about 99% sure it's a better switch than the original.
I hope so. Just ordered themI'm about 99% sure it's a better switch than the original.
You're having problems with the mic also?You would have to say that.
Okay, mine are ordered.
I took mine apart, changed the battery and cleaned the switch after about a month. Was told it was scratch sounding. Better after I cleaned it, now back to being crappy. I've only had it 3 months.
