M-216 BIG DADDY Antenna
My laptop is a boat anchor, so...
Reflector 216"
72"
driven 211.5"
54"
1st dir 205.5"
63"
2nd dir 200.5"
70"
3rd dir 199"
That should give you a good, hand grenade close, model to work with.
Reflector 216"
72"
driven 211.5"
54"
1st dir 205.5"
63"
2nd dir 200.5"
70"
3rd dir 199"
You gave me 214" inches the other day.
Now you tell me the driven element is 211.5" inches. I don't trust anything you say.
This is why I posted the following.
You suggest a 17' 10" length for the driven element 214" inches. I can use that to adjust my model. Why don't you give me the other dimensions for the reflector and directors...else I make a mistake in understanding how you apply the percentage deviations you suggest along the boom. Also supply the spacing you recommend too. I don't want to spend the time modifying my model just to find out I figured a percentage(s) wrong and got the spacing wrong.
I was trying to be nice. I figured you might be up to your old tricks...claiming one thing one day and anther thing on another day.
You do the model.
(blah blah blah blah...)
You do the model.
No, YOU do the model, I don't care about Yagis.
- I'm a Quad man and anything I offered was simply meant to ballpark you into the arena since you seemed to be in need of a starting point.
- or didn't you read my last line:
"That should give you a good, hand grenade close, model to work with" ?
I've been incredibly busy lately, hence the scarcity of posts, but from now on I'll refrain from addressing your questions as I tire of putting myself in the position of being the one currently in your attack sights.
  • @ Tim Chambers:
  • @ AWP:
  • @ wavrider:
    sea que sea que,
