Hustler new tronics 27TD base antenna
Straightshooter58
57
29
28
70
Rockwall County, Texas
Does anyone have set-up instructions or parts for a old Hustler 27TD base Antenna. Its been in my brothers basement for years,and never put up. Its missing instructions and hardware. I've tried to contact New Tronics several times to see if anythings still available, but they never returned my emails!
If anyone has any info/instructions/parts for this antenna..I would be more than happy to buy them from you!
Any info on this antenna will help also. Thank You.
Yo ER58: The advertisement calls for the vertical element to be 22Ft and 3/4 inches tall and ground plane radials to be 108 inches. That should be a ball park close start. Good luck. A antenna analyzer should be used to see just were the lowest VSWR is and allowing you adjust it were you want it frequency / VSWR wise.
when i multiply 36 feet x .64 i get about 23 feet
  • @ nomadradio:
  • @ c316buckeye:
    no conditions in ohio
