Thanks!! I already read through that one. The MARS mod is something different. It opens up transmit on some specific military channels. I did find the mod shortly after posting this on here http://g3ynh.info/commercial/TS430.html . It was as simple as unplugging a connector. User will be happy.Here’s what I found. Typically you’re looking for the Mars modification and not an 11 meter mod. Found on the Copper forum and radio mods.
Patzerozero
Senior Member
Username: Patzerozero
Post Number: 4293
Posted on Saturday, June 21, 2008 - 1:17 pm:
Transmit enable for mars/cap frq for the TS-430S
For MARS and CAP transmit capability, a minor change is required:
1.Unplug the DC power cable.
2.Remove the top and bottom covers of the set.
3.Locate the RF unit connector 10. Diode D39 is near the connector (labeled D39 on the circuit board). Take a small pair of diagonal cutters and clip the lead at the top of the bend.
4.Locate IC-2 on the Control Unit, under the IF unit. Resistor R148 is near IC-2, clip the resistor lead.
5.This completes the modification. Reassemble the unit, being careful not to pinch any leads.
or:
General coverage in transmission for the Kenwood TS-430S
1.On the the bottom board of the transceicer find the RF-UNIT (X44-1510-11).
2.Near the two plugs numbered 9 and 10 , you will see two diodes called D39 and D40.
3.Simply cut the two diodes D39 and D40 on the RF-UNIT.
you're on your own as to which mod you need, but if you're careful, it can be undone. best bet is to go to www.mods.dk & go to kenwood the ts430 & look at the mods there
Thanks again!
DO NOT UNPLUG THAT CONNECTOR. While removing that connector does break the TX inhibit line, it also bypasses the radios ability to protect the finals from burning out. Only one of the wires in this connector are the TX inhibit line. I believe it's labeled "TXI" on the schematic. The others are related to the ALC and protection. I've seen more than one TS-430S come into the shop with blown finals and that connector unplugged.Thanks!! I already read through that one. The MARS mod is something different. It opens up transmit on some specific military channels. I did find the mod shortly after posting this on here http://g3ynh.info/commercial/TS430.html . It was as simple as unplugging a connector. User will be happy.
Thanks again!
Gotcha Shockwave. I'll plug it back in. Is it true that the Mars mod opens 11 meters as Six-Shooter suggested?DO NOT UNPLUG THAT CONNECTOR. While removing that connector does break the TX inhibit line, it also bypasses the radios ability to protect the finals from burning out. Only one of the wires in this connector are the TX inhibit line. I believe it's labeled "TXI" on the schematic. The others are related to the ALC and protection. I've seen more than one TS-430S come into the shop with blown finals and that connector unplugged.
Yes the MARS mod opens all band transmitIs it true that the Mars mod opens 11 meters as Six-Shooter suggested?
We call it the "Masonic Lodge Handshake".
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
