The stand off is oak. The center is carbon fiber I think.Mine is oak wood
That's what I thought too. I was kind of disappointed when it didn't get better being hooked up wrong will do it.thanks for all the helpIf that is true, then something is wrong with the way you did your Doublet. The Doublet if correctly done should have much greater "capture area" than the CB antenna on most shortwave bands.
carbon fiber
I switched to coax and pl259
Do you look the two ends of the laddersolder shields together and uses centers to come thru and connect to screw terminals
Loop the ladder line at coax transition?solder shields together and uses centers to come thru and connect to screw terminals
The wrong way I fixed it.That depends on how you connected the ladder line to your receiver. How did you do that?
I will buy as soon as funds become available,thank you.http://www.vintagemanuals.com/manual/Lafayette/HE-80
We use only high-quality bond paper and reproduce as near to the original as possible up to 11 x 17 fold-out pages. In many cases, these are more readable than the originals because they are not paper worn, "bent, spindled or mutilated".
- All of our manuals are comb-bound to lay flat and fold-out as needed. We print on two sides if the original was two-sided and extra copies of schematic pages are included with Service Manuals.
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
