VQuad great Beam a full wave delta loop design if you want some more performance Maco now makes a 3 element version of the VQuad the VQ3
I have a V-quad, and I can't complain about it I think it's a decent little beam, made a lot of contacts on SSB with it. I was thinking sometime in the future of buying another and running stacked V-quads. Might not be a big time setup, but it would look big time. My wife has already started grumbaling about it, so I know her thoughts about it. Just wondering what y'all think?
In the 70's I had a single set of the Original Wilson V-Quads & I Hated them.No matter how they were mounted my Starduster & Super Scanner kicked their butt.I took them down & gave them to a friend who stacked them & he was disgusted with them as well & after a couple of months took them down & destroyed them.For me they would rank up there as the WORST Base CB Antenna I have Ever owned or used.
SIX-SHOOTER.
You were not doing something right. Probably the phasing was wrong. that is NOT as simple as people think. Simply cutting a length of coax and thinking things are right is the WRONG way to approach it.
It was all Factory purchased.We followed the instructions down to the T.SWR was great but they SUCKED badly.I knew several others who had the same results from the antenna & quickly removed them as well.Many went with a 3 element yagi & had far better results as did those who went with the Y-Quad & PDL II.
SIX-SHOOTER
It wouldn't be the first time factory directions were wrong. Cushcraft has the stacking distances on their 2m 13B2 yagis over a foot too close for maximum gain. Truthfully a single three element yagi should have beaten a Starduster and performed very slightly better over the Superscanner. A dual stack should have been noticeably better than either. As for the PDL2 I agree. That was a great performer in a small package.
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
