The Needle, narrow vertical loop antenna plan
I have tested 2 coil baluns with this antenna, a 4:1 nd a 6:1 , I did not get great results best match has been with the 1/2 wave times velocity , coax balun. Getting nice low swr on my 2 diamonds at around 1.3 to 1, pretty flat across all 40 channels. I have one up vertical and one up horizontal, modeled gain horizontal is 8.03 dbi at 21 feet to the bottom wire.
Can this be fed with a 6 ft. length of 75 ohm coax for matching?
No that would work for a quad at 125 ohm, this is around 270 ohms, the balun is very simple to make just coil 143 inches of coax, on a 6 inch form and wire as shown in the diagram, Made mine in 10 mins. Have swr 1.3 across all 40 channels, on both of my diamonds, one vertical one horizontal.
    AKA- UDX122
  • @ nfsus:
    RFactive has left the room.
