Power supply's
Check out .......
powermaxconverters.com
Have the PM3-LK, a PM3 will do the same. Quality without The big price. You can call them and discuss your needs, if they are open. This crap going on has shut down everything. You can find those same converters on Amazon for a good price. They are also able to be run continues voltage of desired setting.
USA made out of Florida.
You can get a 60amp dell server power supply for under $20.0 on eBay
Been using one for years.... No problem
Reactions: oldtymer
The trick is getting a server supply with enough documentation (OEM or community) that allows easy modifications
Reactions: LeapFrog
Check out .......
The powermax 55 has a good price but are the adjustable.Also the megawatt looks good to
  • @ nfsus:
    RFactive has left the room.
