TS-520
Pretty sure there are three 10-meter crystals. One for each segment of the band.
One of those three will be easier to access than the others. It's a bit clumsy to get the old crystal unsoldered. You'll typically need to use desoldering braid. Getting the new crystal in its place is only a little less clumsy.
Manuals for the TS520S and SE can be downloaded from www.mods.dk
Reactions: tecnicoloco
Got friend go help on this .the guy was going to help me but pass away
Wil o need oscillioscope to line back up or just manual thanks for information
Good chance it will work just fine by changing the crystal alone. If you're just determined to 'peak' the 10-meter adjustments to favor 11 meters, the service manual has the alignment instructions, and lists the equipment they think you need for the job.
  • @ Tim Chambers:
  • @ AWP:
  • @ wavrider:
    sea que sea que,
