Portable power and radio kit - home build?
Littlears
Aug 16, 2020
43
58
18
44
Has anyone built a home brew radio/ battery / solar charge / dc power supply case?
I’m thinking of building a radio in ammo can type setup but could use some help with products / design “gotchas” to get started
any lessons learned you all have would be good to hear!
Reactions: 357magnum
Welcome to the Forum Little ! (y) I used & old Plano Box Rack that held 4 box's ( trays ) , w/ box's removed , I installed my Old Cobra 140GTL , 250 King Bee Amp , Meter , Hand held Scanner ( slid on the side ) Old RS Spkr mounted on top , plus room to keep a Stock Mic in case I need it . I like it , it has a handle , easy to carry in/out w/ Anderson Connectors . But just recently had to reinforce it to make up for the cutting I did on it . Just a thought , worked for me . Stay Healthy & Safe ! 73 & God Bless ! Leo
thanks! Would you mind sharing some pictures?
Simple MC4 panel mounts (for solar panel). 20ah battery inside, 10amp solar controller, and I used a 3 pin aviation plug setup to prevent polarity error. Here it's shown with simple 110v 190w inverter you run a small fan when power went out. Again never used a panel with it yet but a 50w-75w would be overkill to charge the 20ah battery.
I was wrong earlier. Just a plain poly 50 cal can (not FAT50)
I run all portable for HF. Normally with LiPo batteries, some 3 cell, some 4 cell. in mainly a KX2 radio and a 50 watt amp. Due to trying to eliminate weight I don't use a box deal, but pouches.
For radio only I use a 4 cell LiPo 2600 mah battery with a voltage reducer in a small utility pouch, this combo giver me about 4 activations of use. About 1 - 2 hours each activation, for 3 years of use with no problems so far.
For the amp / radio, same voltage reducer and a 5500 mah 4 cell LiPo in a larger case. Running about 50 watts gives me about the same duration. This is of course year round. Below -20C the battery goes into a pocket when using.
what solar controller & panel setup are you using?
have you had any success with portable antennas for cb / gmrs / ham etc? (Not car mounted , but truly “portable” )
If you could post some pictures of your new setup, that would be great. I am going to put a can together to take on beach trips. I have a Midland GMRS mobile and an Anytone Smart that I plan to stick in it. Might make a good command center for the golf cart too. Haha!
im kinda thinking of doing the same. What antenna would you use for such a portable system?
I'll try to get a couple photos this evening... here is one I have available...
    May 15, 2024 @ 14:55 UTC
    Everything is El Dead-o. Joy!
    Please advise me to what is a good replacement mic for my SR-497HPC... Answer: 497 is "wired like Cobra", so many choices available. That radio does not need a power mic, so purchase a stock "coffin style" mic with a decent cord, like the ones that Astatic uses. The Superstar DM-507 is my go-to. https://www.ebay.com/itm/3050474478...adANq91JSiEEnz8EGqPJRBloTgEyaVsBoCtoMQAvD_BwE $12.99 + .99 cent shipping.
