For VHF/UHF, the TRAM 1181 with a Nagoya Ground plane kit is widebanded enough to cover 2M Ham, MURS. 70cm, FRS/GMRS
cool ! What about cb?
I'll try to get a couple photos this evening... here is one I have available...
It is actually a "Aircraft Flare Can" same width/height as a 50 cal can, but about 3" deeperis that a 50 cal box?
I was thinking of using a president cb for this project. Plus a gmrs and a spot for ham if / when I get my license.Base or Mobile?
For reference, this is the same size can with B-Tech 25x4 and a 12v/30a power supplyView attachment 40287 View attachment 40287
I’ve been playing around with box layout and was wondering if I could get your feedback on this version?
Any products you think which are unnecessary or redundant? or perhaps there’s a better version of a product I should use? How about Air flow design? Power vs rf separation?
thanks!
i built a solar generator back in 2007.Has anyone built a home brew radio/ battery / solar charge / dc power supply case?
I’m thinking of building a radio in ammo can type setup but could use some help with products / design “gotchas” to get started
any lessons learned you all have would be good to hear!
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
