Ok, same analyzer i have. Your user manual will show you how to operate your R, X chart and a lot more.
Hook your antenna up to to the analyzer.
Press 3/fq range
Set center frequency to 27205 and a sweep range of 17500kHz
Press OK
Arrow up to R, X chart, press ok
Press ok to start.
Resonance frequency is shown at the bottom of the chart.
SWR chart will show you where your lowest swr is.
X/cancel will take you to home screen
To check other channels/frequencies press 3/fq range and change the frequency.
My best advice is to get more familiar with the analyzer itself then work with the antenna. Thats what i did and im pretty green to the technical side of antennas. I had do the crawl, walk, trip and fall game hahaha. Still havent learned to run yet but i know a lot more now than i did. Google can help answer some questions also.
![16007055318322540101146696745152.jpg 16007055318322540101146696745152.jpg](https://www.worldwidedx.com/data/attachments/37/37920-d844e53b751213fa0afe899862f9a79a.jpg)
The user manual is easy to follow. Dont be afraid to play with all the different functions
Im on a dummy load so pay no attention to the readings.
Press 3/fq range
Press OK
Press ok to start.
![16007051339502739462770631725194.jpg 16007051339502739462770631725194.jpg](https://www.worldwidedx.com/data/attachments/37/37918-c328bc4a3bf145b0c897b290f2bc9c36.jpg)
![16007051619364175989570504722390.jpg 16007051619364175989570504722390.jpg](https://www.worldwidedx.com/data/attachments/37/37919-5e40c9b5e67ed18b0d68e05c625a543c.jpg)
