Looked for them at a ham shop I buy at and they were sold out recently when i ordered a rig expert
Thanks All...
This has been a very informative thread. I have a Clear Speech speaker... I haven't hooked it up and was thinking of selling it but ... after reading this thread I will soon be hooking this up to my mobile set up.
There are some vids on YouTube showing how much noise this speaker cuts. Pretty impressive!
I had the same problem with my Lincoln II plus but it was horrible unless I used the talk back then it went away.Just in case anyone runs into the same
I noticed mine had a “pop” when the mic was keyed. I got used to it, and didn’t bother much with it.
Then Ralph (S&W357) ran into the same with his when connected to his AT6666. He quickly found that if you keep the speaker volume low, and turn up the radio’s volume, the “pop” goes away.
After he shared that tip I tried the same and it works for me too.
My clr speaker developed the same static problem when I unkey but mine lasts 10 seconds or more. But it only does it if I have a short key. If I am long winded it didn't do it.I'm testing out a BHI version currently. Only negatives I've found -
I think these units are impressive as long as you only use the first stages (for voice) when you turn them up stronger it just makes voices too strange, but it could be used for CW at higher levels I guess.
- when you turn up the DSP past level 3 you start to get the waterfall sound in the background. This is common with lots of DSP speakers I've heard.
- when you unkey there is a 1 second period of increased static while the DSP reacts and kicks in again. I find this super annoying.
- the BHI model picks up RF easily. It has a ferrite on the cord but when sitting close to radios it acts like talkback. Had to move it quite far away.
The delay and the increased static after unkeying before it reacts drives me nuts though so I stopped using it after a day or two of testing. Going to do some continued testing with other radios this week.
Maybe that is why the company hasn't had any new ones for many months.My clr speaker developed the same static problem when I unkey but mine lasts 10 seconds or more. But it only does it if I have a short key. If I am long winded it didn't do it.
Perhaps, but they are based near milw,WI and between the Rona and the governor it's anyone's guess.Maybe that is why the company hasn't had any new ones for many months.
Yeah I'd be interested in buying one but after using the BHI speaker with that static noise on unkey I'm not sure I want to risk it again, even if it's the CLR Speaker model. You guys having that same issue with the CLR Speaker is scaring me![]()
