Base Hex Beam for 11 Meters!
Light duty or TV antenna rotor will work on those light beam and they are not expensive
Yeah that's the big benefit of the V Quad, Moxon, Hex Beam is that you can go with a light duty rotor. It doesn't take much to turn these. If you went with a aluminum mast section to connect to the Hex you could also keep weight down further.
Reactions: tecnicoloco
The cost is the entire bill of materials, not just a TV rotor. Consider the mast adapter for a rotor, the rotor cable and cable running, the rotor adapter for tower/mast, the rotor controller, etc ,etc.
  • @ nfsus:
    RFactive has left the room.
