RM KL503 & SSB compatibility
Maybe @NightThumper can chime in here, he's used the 503hd and I'm pretty sure that it's been on 11 meters.
The KL-503HD works great on SSB 11 meters. No modifications and good reports. Before purchasing the KL-503HD I seem to remember reading I believe on the Copper Electronics forum someone complaining about the plain Jane KL-503 on SSB, can’t remember off hand what they said the difference was on SSB…I’m thinking it had something to do with the delay on the 503 vs 503HD. Again my 503HD worked great on 11 meter SSB no complaints from me or anyone else.
Used three radios on SSB with the KL-503HD….IC-7300 (turned down), DX99V2 and RCI2950 (not jacked up)
Brad
South of Pittsburgh
One of the nice things about using the IC-7300 (Ham radio)is that unlike Export or CB SSB radios, when you turn down the power the PEP goes down as well on the IC-7300…try that on an Export or plain CB radio. Only way to cut PEP on those radios is to cut the mic gain. The only thing variable power typical cuts back/down on is Dead Key AM, otherwise PEP is nearly the same across the board. That’s the way it is on Galaxy, Cobra and Lincoln.
Thanks for waking me up there Eldorado828…LOL
Edit 1:52pm EST: Added pics from early KL-503HD output
Brad
South of Pittsburgh
Glad I haven’t gone to hooking up willy-nilly without some advice as seen here and in other threads.
Guys,
I decided to ditch the KL503 & instead amend my order to a KL505.
I'll no doubt purchase a KL503 at a later date, though, if the price is right.
I'll update this thread on Monday when I've tested the Amp'.
If you don’t mind me asking what vendor in the US had them in stock?
I’ve seen a few disclaimers that they won’t ship to the US
Thanks
Brad
Reactions: secret squirrel
The 505 arrived today & works a dream on 11m, @Handy Andy.
Sounds great on SSB, uses 4 x RM SD1446 Transistors, and here are the results: 4w in = 150w out, 5w = 180w, 6w = 200w, and 7w = 220w out.
I didn't want to push it anymore than 7 watts, and I only keyed for about 10 seconds then.
Only curious, but what's the highest input and output power this would accept & do respectively?
Here are some images of the internals. Seems it uses 4 x "RM SD1446" Transistors, but I'm certain the SD1446 were discontinued years ago - so I'm not sure what these are?
PS - L1 to L4 are missing on this (close to the RTX socket)20210802_214220.jpg 20210802_213700.jpg
PS - L1 to L4 are missing on this (close to the RTX socket)View attachment 46171 View attachment 46172
So on SSB 7 watts PEP gives you 220 out? Wow, must be very much a low drive amp.
Reactions: Dereka5
I find this interesting.
In the USA - these spots are important...
Re-read the first few posts you'll see where this reference comes into play.
(HINT: SWR BLOCK)​
That's' where you'll find it...
So the euro version has sd1446 while the US version has the rm3 & rm4?
Or is this a completely different animal?
I'm not convinced they are SD1446, even though they're labelled as RM SD1446.
As far as I'm aware, the SD1446 was obsoleted a while ago.
Furthermore, the SD1446 is capable of easily doing around 80W, so 4 x SD1446 would do 320W if pushed - but no more than ~240W will be achieved from the KL505.
I do wonder, though, if RM got a big batch of SD1446 rejects (low gain), hence why they're marked RM SD1446.
On another note, the schematic diagram provided with this KL505 says they're using 4 x SD1407 which are expensive 28V devices!
  • @ AWP:
  • @ wavrider:
    sea que sea que,
