This set of filter caps came out of a Drake L4B power supply. Took them nearly 50 years to go bad. Yes the date code really is from 1973.
The upgrade used a modern double-sided printed circuit board with snap-in filter caps and rectifiers. All on one board. The one in the pic is only half the original setup. One board like this on each end of the cabinet is what went in at the factory in 1973 or 74.
Got to thinking about how long it takes to find out what kind of service life a component can deliver. In this case, nearly fifty years. Definitely better than average.
But by the time you find out what lasts a long time and what doesn't, it's too late to take advantage in any way.
Can draw only one conclusion. All you really need is a time machine. Go back and fetch a case of these.
Odds are they would outlive you and me, both once they're installed. This is not the first Drake L4-PS we have seen with caps that still work after almost 50 years.
Just one problem. You'll get pestered to also bring back some 8908, 2057, 8950 tubes and such. Gotta figure every time machine has a load limit, so this could be a dilemma.
Just one piece of advice before you go. Check the dates on your cash first. Wouldn't want to get locked up in 1973 for counterfeiting and not be able to come back.
![gd8I5C.jpg](/proxy.php?image=https%3A%2F%2Fimagizer.imageshack.com%2Fimg922%2F5660%2Fgd8I5C.jpg&hash=c494f222d2907ecb76b699cef6827c32)
