I have a brand new never opened anytone 6666 and a KLV550 amp. My issue is the radio will do 2 watt dead key thats fine but only swings to 5 watt and will not drive the amp. Anyone have any suggestions?
OK, what type of meter and antenna are you using to test? Those measurements won't be very accurate but good enough to safely say the radio seems to be working correctly. Looks like a tune-up would resolve the swing. You could simply turn up you modulation but really it need to be done using the right test equipment so you don't make it nasty. Is there a reputable shop near you?I dont have a dummy load
low power dk 2 watt
low power pep 5 watt
high power dk 15 watt
high power pep 45 watt
radio is bone stock
using an a99 and there is no one close to me my tech is down for a whileOK, what type of meter and antenna are you using to test? Those measurements won't be very accurate but good enough to safely say the radio seems to be working correctly. Looks like a tune-up would resolve the swing. You could simply turn up you modulation but really it need to be done using the right test equipment so you don't make it nasty. Is there a reputable shop near you?
Sounds like the radio is a little anemic for the amplifier as it sits. A good tune-up should take care of it but don't let anybody talk you into a swing mod or that kind of garbage. The quad 6 once set up correctly will have plenty of modulation.using an a99 and there is no one close to me my tech is down for a while
snake custom radio said he can tune it and set it so it will work right for 55 dollars including return shippingSounds like the radio is a little anemic for the amplifier as it sits. A good tune-up should take care of it but don't let anybody talk you into a swing mod or that kind of garbage. The quality 6 once set up correctly will have plenty of modulation.
Do yourself a favor, search this site for info about Snake Radio.snake custom radio said he can tune it and set it so it will work right for 55 dollars including return shipping
Good reply, I didn't know what to say to that!Do yourself a favor, search this site for info about Snake Radio.
Ill let my tech look at it once he gets done movingCarefully adjust W5 AMANL
if you had his radio im thinkin western swing,bob wills 10-4?Good reply, I didn't know what to say to that!
