the owners manual does not really tell you any thing about the radio. I own one and have not used it in years. are you wanting the owners manual or are you wanting the service manual for align etc. use to be a lot of radios made under other names but was the same as the 1000.
here is some info for the service manual if that is what you need.
http://www.cbtricks.com/radios/cherokee/cbs1000/index.htm
Anybody know where I might be able to purchase/download the CBS-1000 owners manual?
Any chance of getting a copy of the owners manual?Yeah, I have the Owners Manual for a Northpoint CBS 1000 which is the exact same radio. I can make copies for my cost.
Many thanks for the information... Dan
Here's a copy of the Cherokee. A little different than the Northpoint manual. Some of the pages might be askew, and I think I got a little bleed over from the page's on the back. I'm still trying to figure out the scan settings with the ET-8500 since I reinstalled WIN7. I had the settings dialed in once before, now I've done a clean install, I'm back to square one. Hope this helps.Any chance of getting a copy of the owners manual?
Thank you for the info... DanHere's a copy of the Cherokee. A little different than the Northpoint manual. Some of the pages might be askew, and I think I got a little bleed over from the page's on the back. I'm still trying to figure out the scan settings with the ET-8500 since I reinstalled WIN7. I had the settings dialed in once before, now I've done a clean install, I'm back to square one. Hope this helps.
Also there is this addendum.
Quite welcome. Here are a couple of other things you might be interested in.Thank you for the info... Dan
Smokinone...Any and all info is appreciated....thank you... DanQuite welcome. Here are a couple of other things you might be interested in.
The Intek is the same as the as the CBS-1000. Not sure if any of this is still floating around.
