1/12 coaxial match transformer...
In the absence of the antenna analyzer, you can use a SWR meter, dummy load and coaxial "T" adaptor too. Connect the "T" directly to the output of the SWR meter. Connect the dummy load to one port on the "T" fitting and the unknown length of 75 ohm cable to the other port on the "T". Trim the open end of the 75 ohm coax until you have a flat SWR on the desired frequency.
wow now that is a great idea... I love this hobby
  • @ wavrider:
    sea que sea que,
