2517 issues
Nov 27, 2016
8
5
13
54
I recently traded up a galaxy 2517. The older version with a 2166 driver and two 2312's. I can not for the life of me get it to swing more than 6 watts on am and 8 on side band. Also noticed the variable power will only turn up to 3 watts no matter where you adjust the high low inside the radio. What do yall think is going on? Maybe the driver shot possibly? One or both of the finals damaged? The radio is in pristine condition cosmetically and the only thing that appears to have been done to the radio is the cb band conversion. Any thoughts on it would be greatly appreciated.
Thanks guys
I've went through the transmit alignment procedure for the 690010z board. Still 6 watts. I'm wondering if I don't have a driver or a final bad
Easy way to check. Desolder the base on one of the finals, check output. Resolder and do the same with the other final. Whichever one shows no output when its base is soldered is defective.
- 399
  • @ ShadowDelaware:
  • @ nfsus:
    RFactive has left the room.
