2995 dx no sound
Strikesmith
May 30, 2009
41
16
18
Greetings Gentlemen,
I have a 2995dx that transmits,recieves but no sound,even when I plug external speaker in,Yes squelch
is turned down.
Regards,
Strikesmith
Reactions: Rwb
But would PA work - try PA.
IF no audio suspect Audio amp chip and support parts...
Also check GNF board, and J25 connector make sure all wires to those connectors are seated...
Reactions: Rwb
Gonna give both a try,Got the radio last week,its a mess,ebay deal was working ok then next morning no sound,was bounced around pretty good in shipping!
Thanks Guys!!
Reactions: Rwb
There are two variants of the board, one with the TA7222ap and TDA2003 chip (5 pin).
The GNF "noise filter" board can interfere with audio - but would TX ok.
Else get to the link Robb supplied - and remember to look for the chip design and the layout is update on the TDA2003 5-pin chip.
Have fun...
Reactions: Rwb
This radio is a true screwdriver special.power out is controlled by mic gain,output power on front panel doesn't do anything,has switch on back for power mod,lol,but came with dual fans..wow!!
Reactions: Rwb and binrat
wondering if somewhere in progamming memory whatever if theres a MUTE mode,I accidently activated
We gonna get this worked out,Thanks HA!!
Reactions: Rwb
More than likely a audio mod in there that's failing.
If my hunch is right they use MOSFET for switching power loads - so to have one fail or the speaker quit working - shows that the original designs' been modified - to what? I don't have much to go on, just your words...
Reactions: Rwb
    AKA- UDX122
