well I called yaesu and tec said to put 5.3585 in ch 3 so I did and works good
yeah, the radio may xmit there but,................the tech is
wrong. set the VFO to 5.357.0 USB 5.357.0 USB IS 5.358.5 MHz center of channel
the DIAL freq can be DIFFERENT depending on the mode used. USB & PSK MUST be 1 1/2 Kc
lower than center freq.
CW may (or may not) be 600 Hz off depending on your particular radio.
in clear words 5.357.0 USB & PSK
5.358.5 CW minus any tone offset
READ this chart:
New 60 meter band 5MHz Channel List:
General, Advanced, or Amateur Extra Class license only.
Suppressed Carrier USB VFO
Dial freq
5330.5 kHz USB (center of channel = 5332.0)
5346.5 kHz USB (center of channel = 5348.0)
5357.0 kHz USB (center of channel = 5358.5) New!
5371.5 kHz USB (center of channel = 5373.0)
5403.5 kHz USB (center of channel = 5405.0)
These frequencies are available for use by stations having a control operator holding a General, Advanced or Amateur Extra class license. It is important to note that
the frequencies shown above are suppressed carrier frequencies – the frequencies that appear in your transceiver’s tuning display when your transceiver is in the USB mode.
Note: FCC deleted the channel at 5366.5 USB (center=5368.0)
and "replaced" it with channel
5357.0 kHz USB (center=5358.5)
notice the DIAL freq is 5.357.0
its your license, not the "techs"
