pinejuice said:which would you prefer?
palomar skipper comes with the 8950's how much to retube vs the oher with 6lq6's
no not my intent to change it like that..my question was which would be the better amp the one with 8950's or 6lq6 in a 1x3 configuration..paws264 said:pinejuice said:which would you prefer?
Too Much.............. to change that amp to 'LQ6's from 8950's.
The 6LQ6 is a 6 volt tube using a 9 pin socket while, the 8950 is a 12 volt tube using a 12 pin socket. A better idea might be to re-wire the socket to use 6LF6, 6LR6, or 6KD6's; the only change would be to pins 1 and 12.
