I have an aluminum puck mount that is mounted to aluminum and after a year or so the mount gets corrosion on it. Any conductive paint or coating or other I could use to stop it? Thanks.
Thank you. I have read that one, but T-9 was not mentioned. I read the anti-seize may harden if left on a long time? I was looking at conductive graphite spray coating, every hear of using that?Clean the conductive mating surfaces and apply zinc conductive anti-seize compound, tighten down, wipe off any excess anti-seize, then apply a coating of Boeshield T-9 to the outer surfaces and wipe dry (repeat every 3 months). The Zinc antisieze is meant for aluminum joints and will keep oxygen out and the boeshield will dry with a thin waxy finish (even though it is a lubricant) and will keep oxygen off the surfaces.
