Ameritron 811
airplane1
Apr 15, 2005
1,051
32
58
Lebanon county PA
I think I over heated two of my tubes when learning to tune this amp. I am getting shiny blister looking spots on two of the tubes. this is in the gray square part in the tubes.
Is that what I look for??
Thanks
That's one of the things you might keep an eye on. Also watching the grid/plat currents along with the output power. The recommended values for that grid current is recommended for a reason. Really pays not to 'push' things very far at all with an '811 tube.
I tune using RTTY like ameritron shows on You Tube. I tune for max rated output of amp (600w) being careful not to key longer than about 2-3 seconds at a time while tuning. Then I back off the exciter power down till the amp puts out 200w put the switch on my radio to SSB and thats about it. I noticed these spots after using the amp a dozen of times. they are about the size of pea or so.
I did use the amp on am but the instructions dont say any thing about it. will this hurt it?
Can I still use the tubes for a while or should I chuck them and get new tubes?
Thanks
Thanks
There is a reason for that,that amp is NOT a good candidate for use on AM.The 811A's will take a real beating if you run the carrier over 75-100 watts. Remember that the pep rating of an AM signal is four times the carrier so 100 watt carrier equals 400 watts pep for AM.The amp is rated for 600 watts flat out but you MUST leave some headroom when running AM.The 811A's will take a beating but it is very common to actually blow holes in the plates by running them too hard in high duty cycle modes like SSTV or AM.
It certainly isn't a 'cure all', but there are 811's with graphite plates. They tend not to burn through like the 'metal' plates do. They will also tend to go bad just as quick if pushed too far. Just wait till you see the glass envelope 'dimple' opposite that burned through place. That's when things really get interesting! :)
I only run 45-55 watts SSB at peak of amp output. I run less into it on am, prob about 20watts.
I am getting one of the Mr pecker tuners, if you do a search you can find it on the net. the thing got all 100% good reports on eham reviews and it makes it hard to blow up the tubes.
I did want to use it on AM though, if I run it with low exciter power will it work or is it not a good idea to uae it on am?
And please advise as to can I run the tubes with the little blisters till they go totally bad or do I need to replace them right away?
Thanks
Ain't that the truth! I have seen the glass soften and suck inwards until the point of failure but on an 833A tube instead. Some guys will replece the 811A's in those amps with 572B's. They are basically an 811A on steroids and are a simple drop in replacement. This gives about two and a ahlf times the plate dissipation rating and if graphite plates are used should last forever in that amp. You will NOT gain any more power output due to the supply voltage and current capability but the tubes will be worked far less harder.
Are you talking drive levels INTO the amp?
Thanks
You can run the damaged tubes but you must realize that there is now a weak point in the plates and meltdown will be easier to obtain.See my suggestion above about 572B replacements. They cost more but are worth it for high duty cycle use.The plates of the 572B's should not even show ANY color at max output in that amp.
Tune the amp up properly and then run whatever drive level you need to see about 100 watts carrier out of the amp and cross your fingers until you replace the tubes.
Yea I am talking drive levels into amp, sorry about not being clear. I am interrested in getting the tubes you are talking about, the 572B and in the graphite type.
When you say they have more plate dissipation rating what does this mean?
Will I tune the same way as with the 811 tubes?
Then will I be able to use them on AM because of the higher duty cycle?
I know, so many questions. Please bear with me I just want to learn some thing here.
Thanks
Tubes are rated as to how much power their plates can handle without some kind of catastrophic failure. 811's have less plate dissipation than 572's (been too long, can't remember and am too lazy to look it up).
The output of a tube depends on certain things. The voltage on the plate being one of them. 811's use less voltage than 572's, which means that the 811's voltage on the 572's plate won't give you full output, or even as much as you can get from an 811. So, running those 572's with 811 voltages will always mean less output than the 572's are capable of. It also means that they are just sort of loafing along, and will last longer than an 811 under the same conditions.
Sound like a really good idea? It ain't bad, but there are some 'catches'. Using 572's in those conditions also means that the resulting signal will be a little bit 'wider' than if the 572's were run correctly. Nothing really noteworthy, but still there.
An Ameritron AL-811 can be 'modded' to run 572's at their normal levels (voltages,etc.), but there are definitely 'catches' with that! The simplest 'mod' is to change the primary voltage on the transformer to produce more secondary voltages. The 'catch' there is that it also raises the filament voltage and that ain't good at all. It will also result in more heat production than the stock fan can handle, and push several other components at -least- close to their ratings if not over. There's more to it than appears on the surface, sort of. Best advice is to don't do that, just get a 572 amplifier. Or a 3-500 amplifier, more better. Or a 3CX1200 which is probably the biggest 'forgiving' tube that's common.
Why do I think I know a little about 811's? Cuz I've got AL-811, serial number '13' sitting on the desk over there. I've cussed that thing since the day I got it. But it worked, and still works after what, 20 years? The later ones are not exactly the same, my wrecking this one so many times is probably one of the causes for that. It's also been replaced by an AL-80A, and now an AL-80B. (That AL-80A was used by a friend to drive a really 'big' amplifier, believe it or not. Don't ask, I have no idea what tube was used in that thing.) None of that's bragging by the way. Well, maybe the #13 thingy, somebody has to be one'a the first idiots to buy something. Right?
It ain't easy being an idiot!
Well I think I will just order a set of 811 tubes (Where can I get graphite 811`s) and get the pecker tuner, run the thing on SSB only.
If I want am power I will get a solid state amp for that mode.
Thanks
If that's how you'd rather do it, that's fine. The same sort of things apply to solid state amplifiers as with 'hollow state' amplifiers, just in different ways. As far as the limitations as to how much AM signal is actually produced, that's still the same (after getting rid of all the advertising garbage). Probably the one biggest 'problems' with solid state stuff is supplying the required current and getting rid of the heat. You're the one who has to decide what/how you'd rather do it. Have fun.
A 572B is nothing more than an 811A with a heavy duty graphite plate.
The filament structure is functionally identical. Same for the grid
811A Mu = 160 572B Mu = 170. Numbers vary a little depending on the source.
You can certainly pop a 572B into a circuit which uses an 811A without modification. If the 811As in your final are melting, switch by all means.
The 572B can take a lot more voltage than an 811A but it does not need it to work properly.
Some offshore and even onshore manufacturers change the specifications slightly. IMHO the Asian 572B might have a higher Mu than 170. This means it needs a lower bias voltage to achieve rated idling current, will drive easier and will also take marginal parasitic stabilization components over the edge. Read FL-2100.
The FL-2100 does have a problem with certain 572B's in it but anything I have heard about the AL-811 or the AL-811H is that there are no issues. The 811A has a plate dissipation of 60 watts whereas the 572B has a dissipation rating of 160 watts. That is a HUGE differance when running high duty cycle modes.Personally I would run 572B's in any amp before 811A's simply because of that alone.
BTW Doc,sorry to hear that you were the "lucky" owner of serial # 13. Man, I would have returned it as soon as I saw the serial number and bought another one. By then it would have likely been serial # 666. :eek:
Well then I guess I can go 572B`s and plug and play. they are more expensive on the ameritron site but if they are tougher and last longer it would prob be better choice than the 811A`s.
I think A search is at hand tonight to find a good price on the net. What is matching sets??
Ameritron shows them on there site but they are more expensive.
Thanks,
Roger
Matching sets are a way to squeeze a few more bux from a prospective buyer.
Modern manufacturing should be able to hold tubes of similar type and vintage to a match without any further manipulation.
    63Sprint has left the room.
