amps
rustyc
Oct 30, 2011
29
3
13
69
need help texas star or fatboy looking for 400 to 500 watts out put radio is a uniden 78 been tuned and peaked 30 watts out put which amp would be the best
If you want to be LOUD and OBNOXOUS and splatter a few channels run the Fat Boy <------- not suggested
so get the Texas Star.. Just keep in mind CLEAN in results in CLEAN out...
No one that I know of likes OBNOXOUS ( unless your going to run the "super bowl" channel then you will need a LOT more then 500 watts)
Couldn't have said it better myself. (y)
Go with the Texas Star.
~Cheers~
You might consider having a variable dead key mod done to your radio. Then you could adjust the dead key from say 1-6 watts from the front or side of the radio. This way you could run several different amplifiers.
As it is right now what does the radio dead key?
A Texas Star 400 or 500 would be nice. A TnT 350 would also be exellent and give you 300-350 watts. If you really want to go big this would be outstanding below, it's a 1x4 amplifier.
TNT T800
Transistors 1 SC2290 driving 4 x 2SC2879
Dimensions H 4 3/4' x L 11' x W 6 3/4'
Amp Draw (maximum) 100
Class B biasing
SSB Delay yes
Pre-amp yes
Driver Required N/A
Power Output (RMS) 400 Watts
Power Output (PEP) 1000 Watts
Driven Power (RMS) N/A
Driven Power (PEP) N/A
install recommended with 4ga wire
and 125a fuse. Max input carrier of
4w or 300w max carrier from amp. Max
peak input 40w.
You are among the clueless :laugh:
200 watts pep seemed to talk as far as 500 watts in my comparison . don't underestimate the effectiveness of a pair of AB biased 2879's or 1446's , easily powered by most every vehicle or at home on a 30-35 + amp PS . plus if you every wanna try SSB you dont have to worry about the loss of audio quality that class C has .
yes yes
I have to agree with NoZNA about the 2950 also Booty Monster on the wattage out-put I was on ten meters from New Jersey USA to Dominican Rep. I could not count all the stations calling this guy. The TS350DV with the RCI 2950 put me next in line I have done this several times to different places 2X2879's I have an Imax2000 not big beam.
  • @ nomadradio:
  • @ c316buckeye:
    no conditions in ohio
