Anybody run these before?
Farmer Brown
Aug 28, 2019
100
206
53
59
I have had these two for years and never even tested them, I have never seen any, like these before, any information will be of great help
Reactions: S&W357
Inside photos will tell the story. Many of these amps are similar, but sold under different names. Names like those with little or no reference. In particular, it would be interesting to see what transistors were used. Among other things, that info will give us the fuse size that should be used. Meanwhile look for any burnt parts. If the transistors are good, it’s probably worth rebuilding.
Reactions: Farmer Brown
This one is from Power Communications Systems, Super Mod with low 100 watts and hi 200 watts. Mighty clean in there for it's age.
Finals are SD 1076 with no hot smell anywhere. I will probably hook it up this weekend and let it warm up awhile.
I did post it's pic twice in the OP instead of it with the Sidewinder 350 which is a 5 pill.
Reactions: S&W357
Sidewinder 350 with SD 1452 finals and it's a 5 pill, Driver is a 1076 UpDate on the final #'s
Reactions: S&W357 and Tokin
  • @ ShadowDelaware:
    AKA- UDX122
  • @ ShadowDelaware:
  • @ nfsus:
    RFactive has left the room.
