This one uses 5 volt phantom power through the audio wire."...An electret microphone is a type of electrostatic capacitor-based microphone, which eliminates the need for a polarizing power supply by using a permanently charged material." -Wiki
I cannibalized the element and plug from the stock microphone but utilized the case, switch, and cord from the Electro Voice 903E.stick with the mic the radio came with. Its about as good as it gets for that radio.
The wiki article is partially incorrect.Not sure what you are asking here?
An electret mic needs no power supply to make it work. It is like a crystal element or a dynamic, in that it makes its own power and output - if the Wiki definition is so.
But if you want to hook up that cool EV mic to the 6666 - and the 6666 has a hot +5v/audio wire; then it will need a series capacitor. The cap will block out the DC +5v out of the audio wire and let only the audio signal pass thru. Understand - that a cap will not pass DC - that is what it can do.
Am I reading you right?
Does anyone have any idea which value/type of capacitor to wire in parallel to the element to prevent rf feedback without hindering the frequency response of the mic itself?
Thanks for the info. I'll give it a shot.Try a 103 ceramic cap. .01uf
Sounds like that did the trick..Thanks for the info.Try a 103 ceramic cap. .01uf
Here is what I Did..minus resistor.Would like to see the diagram and photos of what you did. Looking at doing something similar
I did not include provisions for those buttons, although I can always add them later if I wanted. I was more concerned with Fidelity and less concerned with the convenience of having a channel selector on the microphone.What did you do with the Channel Up/Down buttons? I have the Anytone "Smart CB" aka Albrecht AE-6110 and am trying to locate a wiring diagram for the mic. I'd like to convert it to a rotary encoder switch for the channels and switch to a better mic.
Does your microphone have a plug like this one?What did you do with the Channel Up/Down buttons? I have the Anytone "Smart CB" aka Albrecht AE-6110 and am trying to locate a wiring diagram for the mic. I'd like to convert it to a rotary encoder switch for the channels and switch to a better mic.
This is how the 6666 is wired.Is the AT-6666 wired like an ICOM? If so just copy the capa dn resistor like they do as a starting point. You can always change the cap value and type latter to tune it to your voice. On the other hand if it already has a blocking capa nd resistor int he radio as part of the mic circuit than none of that matter's you can plug in any electret mic with no worry of adding any of that.
Uniden radio's that use a powered electret do not include anything int he mic because all of that is built into the radio. Just depends on how the Engineer's designed the radio.
