Capture Area?
Red Ranger
150
3
I know the more capture area you have the better the receive, but what about transmit?
How much difference would the capture area affect a 108" whip on center of a truck roof vs a monkey made or a "10k" on a semi, both radios transmitting the same power?
Also given that if both are transmitting 40 watts pep, and one is running a Class A and the other a class C amplifier, who would have the advantage in a "shootout"?
That 'capture area' is more a way of thinking about things than actual fact. It doesn't carry over directly to transmitting. An antenna not 'pointed' at a station transmitting doesn't have as much 'capture area' as one that is.
As for the differences in class 'A' and class 'C' amplifiers, when you said both were using the same power output, about the only difference would be in 'quality', not strength. See where that's going?
  • @ wavrider:
    sea que sea que,
    C'mon let me take you on a Sea Cruise! (Maybe there is someone to talk to out there?)
    Just for the Halibut.
    Seems to be dead on the radio lately. I don't know if the conditions are horrible, or more likely my weak antennas. I may head up in the mountains on Wednesday and see if reception / transmission is improved.
