cb stryker 490
military mike
New Member
Jun 25, 2014
8
Hi all I have a Stryker 490 and am getting a shock or small burn from the Mic when I talk not always though. Also it has sometimes turned red when I talk? Any help would be great.
Hows that workin out for ya?? LOL!! Just kidding ;) I know how ya feel as Ive been there my wifes HF rig in her mobile used to get me everytime!! I ended up running extra groun wire off the radio. It only did it in her old carand actually what I ended up doing is using one of the coax lightning arrestor adaptors. It crews onto the radio SO-239 coax connector on the radio and the coax from antenna screws to the back of that. In the center of that barrel typ adapter there is a screw luf terminal that you can attatch another ground wire to and run that ground wire to a good solid ground. Make sure you clean of the metal where you are going to connect that new fround wire if the surface is painted to ensure good solid ground connection and Waaaaaa Laaaaa!!!!
RF feedback from a poor/faulty antenna installation. You need to look at how you've mounted the antenna, the coax connections, how you've grounded it.
Can you give us some info about your antenna install?
Is not the right answer. That masks the fault, it doesn't fix it. In fact it can make things worse by creating a ground loop.
