CB, VHF, UHF, and GMRS all in one
jgorm
Nov 4, 2009
2
Hey Guys! First post. I'm trying to get a radio for my jeep that will work on all common bands. Some guys have CB, some have VHF, and some have little frs/gmrs radios. I'm sure some will have HF in the future, but none of my friends have it now. I understand there are some legal issues, and prefer not to get into that. I'm wondering what radios will do what i want. I plan on getting certification for HF and maybe some of you can help me determine what level of cert i will need. I've been told that the FT-857D will do what i want. I'm also looking for antenna recommendations that will work decent on the different bands. I don't need max performance as most people will be within about 20 miles 99% of the time. The mountains and valleys are the killers of the little gmrs radios i have now. Having a break out box design is a huge plus so i can take the face off. I'll probably weld in a bar to secure the radio guts because the jeep is a soft top and is topless most of the time. If anybody can recommend any other radios that may work that would be great. Thanks!:w00t:
See, that is the problem there. There is no radio on the market that is built to do this and handle the legal part that you do not want to get into. I have seen post like this all over the place and it always gets nasty so look out.
The best bet for your group to do is find one radio that you all can use.
:bdh:
What you are going to run into is an FCC CERTIFICATION issue. Let's talk only about the CB/VHF/UHF thing. Generally speaking, (and I am assuming you are in the US as laws are different in different countries) you CANNOT LEGALLY get or operate a ONE radio-does-all kind of setup. Sure, there can be some exceptions, but the expense would more than it would worth to the average citizen. You will need an FCC- certified, 40 channel CB set & an FRS (VHF) radio, AND a UHF radio, too. AFAIK there is no such thing as a CB set/FRS/MURS combination. There is also GMRS on UHF, and it requires a license. You will also need permission from the repeater owners (if you wish to access them) to get the PL codes. Many of them are what are known as "closed" repeaters.
Now, the FT857-D is an amateur radio designed to be used ON amateur frequencies. It also is NOT certified for use on the above bands and frequencies, cannot legally be used on CB or any of the other services, either. Same goes for what you call "HF". If you DO have an amateur license, then you know all this already. If you are fixing to just buy an all-in-one radio to be used like CB, operate on any frequency you choose, there's gonna be trouble in "river city" so to speak. I'm not here to scold, just to caution you that there ARE some dangers in doing this. Do NOT go ON the ham bands, or begin to use the radio on some "hunting" channel that you may think is 'your private channel" as the legal users of those frequencies WILL locate you and turn you in to the authorities who, BTW, WILL go after you with hefty fines. Again, I am not here to scold, just to let you know of the risks of using HF radio in particular (because it 'skips' a LOT!) "Outbanding" carries risks so you would, I assume, want to know some of them.
CWM
Thanks guys. I guess i'm wondering what certifications i will need for all of these bands, assuming i will buy 3 radios. Maybe after i get certified for all 3 i will decide against going with an all in one type of thing. Is there a good newb thread that describes how to get certified / take classes, etc? I plan on following the laws as closely as possible, but space is my main concern. I wheel with different groups, hence the need for multiple bands. Sometime i wheel alone, so multiple bands would be nice if something bad happens.
1. It's illegal...you know this already
2. It's your decision on what you want to do now that you know it's illegal
3. Yes it is possible to do what you're asking.
Everyone always says, "you're going to get an $11K fine" or some other trouble, but there are ways to do this while not legal, will keep you out of harm's way. Noone who knows wants to go on record talking about it, though.
Since it sounds like you've already made up your mind that you're going to do it, it would probably be helpful to tell you how to stay out of trouble which can be summed up in probably three basic steps:
1. Become familiar with what the frequencies used on the CB/MURS/FRS/GMRS bands are and only use those frequencies. Those are all of the unlicensed bands. Don't go to other frequencies that you think might be "unused"....because they probably are. Program in the frequencies as memories that match the "channels" of each band to your radio so you can't screw it up.
2. Reduce the power output of the radio. For example, don't run 50 watts on a MURS frequency which only allows 2 watts, because everyone will know that you're not running a legal radio if you do.
3. Don't announce over the air to the entire country side what you are doing.
We can discuss some your other questions also, but I have to run right now...
Reactions: NZ8N and Caish
Don't listen to any of these people. Do whatever you want, I'm sure you'll get a warning before the FCC starts handing out any fines. Enjoy it while you can.
Reactions: groundwire
If you buy 3 different radios to do this (CB, MURS, FRS), you don't need any license. Just buy regular, certified radios and you'll be fine. If you want to get your ham license, you'll need at least the General license to be able to use HF/VHF/UHF bands...but that doesn't make it legal to use one radio to talk on CB/MURS/FRS/GMRS. That doesn't mean a lot of people don't do it, though. Be informed of the rules and make your own decision.
To get your General license, you'll have to pass two tests: First the Technician license and then the General license test. You can do them both at the same time if you want. Pick up the Gordon West books (one for each license class) and they basically walk you through the material and tests pretty easily. Then just take the practice tests on QRZ until you can pass consistently.
If you can get all of your off road buddies to get their general licenses, you will really have something valuable for communicating while off-road I have a Jeep and have a decent communication's setup for that purpose. It's nice knowing that you can pretty consistently be able to talk to half of the country if you need to.
BTW, for an overhead locking jeep radio mount, check this out:
10301 - Single Compartment Overhead Security Console, Jeep CJ, Wrangler, Unlimited, 1976-06 | ShopJeepParts.Com
Finding a "one radio that does it all" is more a dream than practical. As far as the legality part, I figure you will do what you want to do, just be aware that there are consequences.
I would also agree that you can't take everyone's word for things. There are somethings that only take a little bit of common sense to figure. You are on your own in that regard. So make it light on your self.
Hello and thanks for this place to be able to learn and share. I'm very new also. I am looking to buy a radio at present, for prepping purposes only. I had the same question of finding an "all-in-one" radio to receive and listen. I realize there are serious licensing issues which of course I honor. I am looking for this sort of radio (or wondering which ones to buy that will be "all inclusive") for a disaster readiness scenario only. In the event of a serious regional or national crisis, and from a prepping standpoint, is there a radio that would receive all frequencies that would help one be informed of public or private chatter? If there isn't one like that ---and pardon my ignorance please--- which types of radios would I be able to get in order to catch all known frequencies to help save life and help our neighbors also, in the event of a serious catastrophe or disruption. Thanks for your help and your patience! I live in Anchorage, Alaska. I'm told there is not much on scanners (not sure what freq. that is) but there is a small amount of CB use and some Ham operators. Best wishes,
humm no pissing matches yet? ya'll sick?
no radio does all. a tech license for every member n buy a 2 meter monoband that has 50 + watts n a good antenna be my suggestion for range in a jeep club. there are some decent 50+watt radios priced decent new on the market
PS welcome to w.w.d.x. and good first post
Post is sufficiently amusing so I'll chime in.
YES YOU CAN DO THIS WITH ONE RADIO AND ONE ANTENNA
Jeeping around out in the woods ..... who cares about being legal on short range radio communications that isn't hurting anybody. Just go for it.
I looked up the specs on the 857D and after the out of band modification it goes up to 470mhz so that will cover the GMRS and FRS radios. VHF is easily covered. CB is covered. And there are other multiband compact HF rigs that will probably cover all these ranges too. The Icom IC -7100 probably will along with their older IC -706 Mark II G ..... probably others.
A quick look in the HRO catalog shows a Diamond CR8900A Quad Band Ant made for 10/6/VHF/UHF. The elements should be retunable to satisfactorily hit all of your desired freqs.
The guys here saying you can't do it or it won't work ..... don't know what they're talking about.
You may need someone to help you who has a HF~UHF Antenna Analyzer to get the antenna setup .... and this radio and antenna are going to cost you some good money ..... but if you have the bucks ... Go For It. Live Now !
If you're just looking to listen, a wide band scanner should do what you want. A scanner isn't focused on just one band or frequency, but should cover from LF to UHF, maybe into SHF. I am not as well versed in the world of scanners as others, but this site and other sites have some well populated forums for buyer guides. No license should be needed.
Reactions: Rwb
