I recently acquired a "Made In The Malaysia" 148GTL. Upon inspecting it today, I found a 68 ohm resistor bridging the base of TR-37 to ground. I believe the original part was supposed to be a 4700 ohm (R226).
Is this somebody's idea of "strapping" it for more power? Maybe a swing kit? Or is this one of those "Manufacturers Discretion per build" thing that happens during assembly and testing?
Schematic is here.
http://www.cbtricks.com/radios/rci/tr_296gk_dx/graphics/tr_296gk_dx_sm_sch.pdf
TR-37 is at the lower left of the schematic near the final transistor TR-36.
My inclination is to remove the 68 ohm resistor and install the 4700ohm in its place per the schematic as I am not able to get the final Bias set below 70Ma.
This small "deviation" is not all of the problems with this unit. Cracked tuning slugs, worn out SO-239, bad RF Gain pot, bad CT2 trimmer, broken plastic mount screws for Audio IC and Balanced Modulator IC.....................
All help is appreciated.
73's
David
Schematic is here.
73's
David
