I remember the “Splitfire” plugs! I am using the oem Toyota plugs and wires. Seems like they last a while. Just changed them last year. They work great!!
Yes..radio DK is around 2w with a PEP swing of 13-15wKL 503 is to be used with no more than 15 watts P to P watts. you will blow it up. KL503HD on 35 watts P to P watts I have both versions
A little fire in the wire! Sometimes you just need a little help, just that extra lil bit of fire.Update:
I decided to go from the KL203 to the KL503….and so far I am liking it!! Thanks to Night Thumper for his experience with 88Radio. Shipped from NorCal and here in a few days. I was expecting it coming from Hong Kong.
I went with the 503 and not the HD version since my McKinley isn’t too powerful.
I am running it at the #2 spot and getting little more than 300w in both AM and SSB with a 45w DK. Amp power increases to around 375w on #6 with a 80w DK. I don’t want to overdrive it and 60w or so less is no biggie.
4Runner alternator is able to power it. With the amp(modulated), head lights and AC there is about a 45amp draw. Although the rpm’s drop a bit when I modulate and voltage drop a bit. I am going to Big 3 the electrical so hopefully that should help. A bigger alt shouldn’t be necessary with only 300w.
Made some contacts on both AM and SSB and reports are that it sounds good. No crunchy sound or distortion. BUT…I need to have my SSB aligned as I get reports that’s it’s off a bit. Clarifier fine tune adjusted a little to the left by locals I chat with. So..my voice a little high pitched.
So anyways I am enjoying this amp at the moment! This should suffice….for now. LOL
That’s what I was thinking!! The KL203 works but an extra few hundred doesn’t hurt.A little fire in the wire! Sometimes you just need a little help, just that extra lil bit of fire.
Is that what you're using in the Yota?
This really is true. Adding power takes you from screaming like a banshee trying to get a return to concentrating like mad trying to copy weak stations. I've had a lot 4x1 and 5x1 contacts lately, but then again, I probably wouldn't have a copy without a modern ham rig. I usually just tell them they are just above the noise, but I don't tell them my noise floor is an S 0.5 lolThe KL203 works but an extra few hundred doesn’t hurt.
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
