Wanting to install trbx3 echo board in my cobra 2000 gtl and have a couple questions. I know pins 2 and 4 are ground so can I use either or both for grounding for the echo board? The instructions shows pins 2 and 4 as ground pins. Also where is the beter place for the 13.8v switched power. Thank you for any help.....
