Cobra 2000 gtl with No transmit limited receive.
The PLL is locking on channel and receives signal from my generator on every channel. So far I have replaced TA7222P, MB3786, TR31, TR33, TR35, D60, Tr24. All Transistors are switching but not getting power thru the SO42P for the 8 volts it needs to kick into tx mode. Tr42 is switching also, I have not replaced it. Voltages are changing on the finals when I key the mic, so I imagin all switches are working to that point. I am tempted to pull up pin 5 and see if voltages rise to 8 to 13.5 volts. I am just about out of ideas on this one and it is going to be a scrap radio real soon, I've got way more time in this than what this radio is worth.
If you scrap it, I would be willing to buy it off you for a decent price and pay shipping
kind of depends on what you are going to use that 13v for, but in general, pin 1 of the audio chip or pin 2 of the voltage regulator will be at VCC.
LC
We rely on pin of the TA7222 audio chip. In part because the trace has room to lap-solder a wire. And it's close to the large filter cap.
Kinda depends on how much current you plan to draw. Something small like a noise toy or talkback module won't cause trouble. Just don't try to power a linear from that spot.
I.got one of these dds-vfo was going to try it out I like the look of it
It will be interesting to see how you get along on this. I have only experimented with the dds types on old 23ch rigs. Got some good results though!
Yeah I know but I'm waiting on my freq counter to come so I can set it up as pre directions even still i.can get it all hooked up in the mean time
Reactions: Holydvr
