Are you sure they are broken? Mine were only stuck. If you take them out there is a screw on the back that controls the pivot of the meter movement. I put a little silicone on the pivots and turned the screw to loosen up the movement. That fixed mine. Counterclockwise seemed to loosen and clockwise tightened.
