Cobra 29 LTD Classic & Chrome FM Radios are Here
CbRadiosPRONTO
Mar 21, 2014
404
128
USA
www.cradiospronto.com
Well, that’s a little anticlimactic. It’s the same radio, feature wise, except FM. Push the channel selector for FM.
Hope it’s ok, I’m quoting NZ8N from another post about the 29LX
NZ8N [begin quote]
The PLL in this latest generation of Cobra 29LX and the new 29 AM/FM models are serial programmed, this particular PLL outputs the VCO frequencies direct.
Here are FCC submittal pictures for the new AM/FM Cobra 29 radios out now. This also uses the same PLL/VCO daughterboard as what the 2nd Gen 29LX now uses.
https://fccid.io/BBO29LT01/Internal-Photos/Internal-Photos-6305096
On Page 11, shows what is under the soldered down metal lid of the PLL/VCO daughterboard, a Beken BK4802P, which is a repurposed FM/ASK chip.
https://www.pi4raz.nl/download/BK4802N_Datasheet_V1.1_EN.pdf
[end quote]
When comparing the new AM/FM radio to earlier model schematics, other than the PLL daughterboard section, and FM daughterboard section, the rest match up (mostly) to the same on the schematics as, say, the 29 LTD Classic. C65 (.01uF or 103) feeding the TX buffer TR16 and most of the rest of the TX and RX, TX Switch TR21, etc... match up.
I did verify that the yellow wire going to the Ch9 switch to the Ch9 pad on the CPU board, when moved to the Ch19 pad next to the Ch9 pad, does make the radio go directly to Ch19, so that would be a good idea for the truckers radios if they wanted instant Ch19. The faceplate won't say Ch19 above this switch, but it works.
The PLL outputs 37.660 MHz on Channel 1 in RX, and 38.100 MHz on Ch40. TX frequencies are direct to 26.965 (Ch1) and 27.405 (Ch40). Both RX and TX "samples" are present at C65 (input to TX Buffer) and JP39 (14mm) which feeds R17 then FET1 (RX 1st Mixer).
There is no mixer frequency. No offset like older 29's.
These use a direct PLL signal of 37/38 MHz to the RX mixer, and direct 27 MHz to the TX buffer stage.
  • @ nomadradio:
  • @ ShadowDelaware:
  • @ c316buckeye:
    no conditions in ohio
