D104
solderjerk
May 4, 2007
23
Shingletown Ca.
I have a D104 hooked to my Pearce Simpson Cheetah. Does anyone know how to get rid of the pop in the speaker when you unkey and/or key. I tried a diode across the TX/RX relay but it didn't work. Thanks
is that radio relay controlled?you hear a click inside the radio when you key?if so make sure the d104 your using is a tug8 stand with the switch inside set to relay operation.could be that.
Yeah its a TUG8, already tried that. I just also noticed that when I turn the band switch it also pops in the speaker so I guess it's not the mic, but the radio. (Back to the drawing board). Thanks.
  • @ Tim Chambers:
  • @ AWP:
  • @ wavrider:
    sea que sea que,
