What dead key setting should I run my general lee at for running a fatboy 450 2 x 2879?
That box should take a 4 to a 6 watt dk no problem, I would just be a little concerned about the pep watts. If it was my box, I would't hit it with more then 20 or 25 watts pep. That is all that is required to drive it to full output, sure if you run the drive up you will see more wattage on the meter, but most of that is heat, not real world watts......
It is a 2 x 2879! 120 watts drive? Holy crap! Yeah if he is keying in a competition it will last a couple keys, I am just saying you can drive it with as many watts as you want till you smell 10 ohm resisters, but realisticly will those watts all be real, on frequency watts?
