Has anybody seen this or have an answer based on common electronics knowledge?
I have a "used", of course, DOSY PM-2001-TS meter. The SWR and Power seem to work just fine however, the Modulation Selection is dead.
I set the "Set/Mod" switch to Set, I turn the Dial to MOD and key the mic, but get nothing at all on the meter. I did put a Fluke meter on it and here is what I found. With the Fluke on Diode / Beep test, 3 of the diodes inside of the DOSY give me a dead short (constant beep). Is it possible that these diodes were blown due the the last owner using this setting with linear hooked up? The 3 diodes giving this reading are: D7, D8, and D10
D10 - .007
D7 - .003
D8 - .018
Anybody? Help?
-jim
D10 - .007
D7 - .003
D8 - .018
Anybody? Help?
-jim
