Dipole around 90 deg corner?
SLR_65
104
16
Hi Guys,
I'm putting a dipole up for my shack, it'll be under the eaves of the house. I plan on orientating it east/west, however north/south may be nice occasionally. I'm considering two dipoles and a switch, but then it occurred to me that maybe I could put it near the corner of the house and fold one leg around the corner.
Would that work to give a move omni directional antenna?
If the house is stucco you'll have a lot of problems with the chicken wire mesh screen. It'll detune whatever you put up within a wavelength or so.
It's not really a "V Beam", either. Those have sides 4-5 wavelengths long and a narrower vertex angle. And they're up a lot higher. Think "half-rhombic".
A 90 degree vertex angle is really too small; 120 degrees is about as narrow as I would want. Narrower = phase cancellation. YMMV.
Reactions: Captain Kilowatt
Hello,
Besides the effect of the house a low placed dipole in a 90 degree angle placed horizontal will have a pattern that could still be considered "bi-directional".
With that said...when placed below halve a wavelength, on the sides the "directional effort" will probarbly not reach the 1 S unit difference.
And above that height it just barely will.
You would also have to bare in mind the the take off angle.
As a low placed dipole will have its main focus upwards, it will still "copy" at low angle but going from say quater wave length to a full wave length in height will provide at least one but most likely more S-units gain at long distance.
Hope it is of use kind regards,
H.
Thanks guys, I just may give it a shot to see what it does.
In my youth I ran a dipole under the eaves of a single story house and it was still directional.
My thoughts were that it would work - it's basically an inverted V placed horizontally.
I'll report back after I experiment a bit.
...In my youth I ran a dipole under the eaves of a single story house and it was still directional....
I dunno about that, perhaps the Tx/Rx off the ends was so poor that it just seemed that the antenna had gain off the broadside.
good luck
  • @ nomadradio:
  • @ ShadowDelaware:
  • @ c316buckeye:
    no conditions in ohio
