Easter Weekend Contest Rules
binrat
WDX Club Coordinator
Staff member
Nov 5, 2008
2,615
1,527
173
The Great White north
Good morning all. Here are the contest rules for the Easter weekend contest.
  • Only contacts with other WDX members count in the contest. The roster may be found as a sticky thread locatedhttp://www.worldwidedx.com/threads/wdx-roster-11-30-2014.28909/
  • Channels: 29 AM, 39 LSB
  • Date/Time: 03/25/16, 0000 Zulu through 03/27/16 2359 Zulu. If you're not sure how UTC time works, check herehttp://www.timeanddate.com/worldclock/converter.html?p1=3875
  • Logs must be posted in theWDX Club Contest Contactsforum by the end of contest. Create only one thread for your contacts. You can edit or reply to your own thread, using it as your log throughout the contest. The format is attached as an Excel file. It may be an excel attachment OR pasted into your thread.At the end of the contest, the contacts forum will be locked, so make sure you upload all of your contacts before the end date/time.
  • There is a 2x multiplier for mobile, portable, or maritime contacts. If you operate as mobile, maritime, or portable during the contest, you are credited with the multiplier for any contacts you make. If you operate as a base, you receive a multiplier for any contact you make with a mobile, portable, or maritime contact. 3x multiplier for any contacts outside of CONUS and Canada. Make sure you clearly designate these in your log
  • No amplifiers allowed, CB legal limit.
  • Contacts will be verified against each others' logs
  • This is an "on your honor" contest and intended to be fun. Please play by the rules.
  • BE A COURTEOUS OPERATOR, PROMOTE THE SITE, AND MOST IMPORTANTLY HAVE FUN!
  • Contest Log - Jan 2015.xlsx
"tomorrow" for me is now tonight!
i'll check this evening around 6ish central time when i get home from work.
If the weather lets up here, and conditions are decent, I'll get on today. Waiting to see what the weather is going to do and also have some stuff to do this morning. Maybe I'll catch someone later if the weather is okay later today! Good luck to all and have some fun!! That is what's its all about anyway!!
WDX0222 Daytona Beach, FL
73 and God Bless.
Sean.
Just called a couple times..could hear my numbers called back but unable to pull out who it was. Conditions not the greatest in central illinois. Good luck all..73..wdx630
little to no conditions here most of the day, i will be calling off and on for a couple hours
wdx724.
i am starting to get south america dx
I just went out back with my Cherokee AH100 SSB walkie talkie to hear what was out there. Not a soul coming in LSB39. Some local stations were talking with guys in Durango, Mexico on AM40, but the Mexicans were fading in and out.
