Not sure what is or who is Alan 87, but during my search I find that it may be an LT2, correct me if Im wrong, the only lettering on the board is "WEP" Im guessing Workman Electronic Products? I had this in a Euro 3900 old radio and Im surprise who say it sounds muddy in this radio sounds so clear made someone think I was running some power.Board from Alan 87. EPT36xx board.
Enabled or disabled makes audio muddy. Tested many times.
The same is in Galaxy 95t2 if I remember correctly.
Mike
I do have all the wires label I made sure I did before pulling it out. I know I can go the echo mic route but not to crazy about dealing with the battery issue. And this will be a little project for me, all tech started somewhere, we all not born knowing how to drive we learn from mistake, level with me just trying to learn, my nearest shop is about 4 hours from me that I know of.First, you should have traced back and labeled all the wires leading from it before you pulled it out of that other radio. It would have been lot easier to duplicate than trying to find instructions. Second, since you’re not a tech, this mod should only be done by those with at least some experience. Third, because of space considerations echo board installs are usually reserved for larger framed radios. My advice is to forget all the hassles of an internal install and buy an EC 2018 Xtreme mic instead. It’s a much better solution that you can also use on other radios in the future. After the mic adjustments are set correctly, it will at least match if not outdo any internal echo boards.
Is that the same as a LT2? I google it up and Bells has the same picture of the board I have.I meant Midland Alan 87, radio popular in EU. Clone of many other![]()
Far be it from me to discourage anyone from trying something new. I’m all about DIY. It just sounded like you were in over your head and I wanted to give you an easy alternative. As a tech, I still prefer the EC 2018 Xtreme, battery and all.I do have all the wires label I made sure I did before pulling it out. I know I can go the echo mic route but not to crazy about dealing with the battery issue. And this will be a little project for me, all tech started somewhere, we all not born knowing how to drive we learn from mistake, level with me just trying to learn, my nearest shop is about 4 hours from me that I know of.
