End Fed Antenna
Lol,
Radiowavz 1:1 current balun. I can dial back to 200 watts, but I'm sure I'll forget one day and poof it.
Any particular orientation the end fed antenna favors? I can mount it in practically any and every direction.
I've always run mine vertical for ~30', west horizontally for ~45', then north horizontally for the remainder. Seems not to care which way I run it...
I do personally think as much vertical as you can go before going horizontal or sloping downward is better for low angle propagation especially on the bands 20m and higher.
Reactions: binrat
I can pull the wire up pretty high in my Oak tree. Maybe have the feed point 6' above ground and 50' coax run to the shack.
If you live where I live you do not want to point it north. My antenna points across lake Ontario towards Canada. It still works well in all direction's. I have a off center I will get up one day and point it west.
  • @ nomadradio:
  • @ c316buckeye:
    no conditions in ohio
